If you were running ok in the winter months, you should be fine now. The fuel mixture will get richer as the air temperature rises. I did a complete retune on my bike over the winter months and got it running very good with just a bit of a cackle. Now with the temps back in the 70's, the bike is running very strong with a nice rich-pop on decel. FWIW I also run my bike on the rich side because I'm an agressive rider with a heavy hand, keeping the tuning rich helps eliminate any detonation problems.
One thing that you might want to look at a bit closer is the fact that your pilot screw is turned all the way turned out. Typically, you don't want that screw turned all the way in or out, usually only a couple of turns. You may need to change your pilot jet.
Scottie J
