It appears the time has come to split my cases. Recently, I began to hear a NEW NOISE coming out from my motor - sort of like humming, metal against metal rubbing with pitch perfectly synchronized with RPMs. A friend tells me it's one of the bottom end bearings. That's exactly what I also believed is the case.
Well, I am going to replace three bearings. I read somewhere that it would be a good idea to use German FAG brand. Where can I order them from? Is it the only brand I should consider?
Thank you,
Andrew
