Just received the inner primary from India from Ebay seller "EnfieldCounty"
and close ratio gearset etc from Hitchcocks.
I used a dremel cut-off wheel to remove the starter gear ring from the crankshaft sprocket, and ordered the studs, nuts, washers etc from Hitchcocks.
The quality of the inner cover is better than I expected, and was "fully packed" as they say. Took about two weeks to get, so not too bad. Really is a nice cover. Piecing the conversion together vs. sourcing things in kit form saves a bunch of money, aside from cutting the gear off it's essentially the same (all gaskets are in the gasket kit I already have) All these parts came out to $35. A viable option I believe for those wanting to save some money and don't mind doing this themselves? Now onto the business of drilling and tapping and assembling the gearbox
