My new ride...
46 Guests, 3 Users
Ice, gizzo, JohnDL
April 29, 2016, 03:11:58 am
Author Topic: Electrically challenged dope  (Read 584 times)
pushrod
  • No good deed goes unpunished
« on: May 15, 2014, 07:08:20 pm »
Well, it's been awhile, about 4 years :-) since I started this simple change. Back in 09 I decided to change my 2000 Bullet so I could turn it's lights on and off at my discretion. Now on my 2000 Bullet USA import, the origonal handlebar controls do not have a  on/off switch (See photo of removed switch) So I ordered an non-import switch that does and installed it on the bike.  I then proceeded to remove the short jumper harness behind the headlight. I have the horn, tail lights, parking lights, brake lights and all dash lights working, Except the headlights high or low beam, unless I hold the spring loaded headlight flash switch on and then my headlight comes on but only as long as I hold the spring loaded switch on.
 I would like to get this to work, 4 years and I still can't figure it out lol. Any advise appreciated
« Last Edit: May 15, 2014, 07:35:37 pm by pushrod »
Pushrod
pushrod
Re: Electrically challenged dope
« Reply #1 on: May 15, 2014, 07:11:53 pm »
More photos:
Pushrod
pushrod
« Reply #2 on: May 15, 2014, 07:15:22 pm »
Photos of new switch
Pushrod
pushrod
« Reply #3 on: May 15, 2014, 07:16:55 pm »
Removed jumper
Pushrod
pushrod
« Reply #4 on: May 15, 2014, 07:20:16 pm »
Bucket nightmare
Pushrod
flyboy
  • Keepin the shiney side up
« Reply #5 on: May 15, 2014, 07:41:03 pm »
I had the same issue with my '99...hated that i couldn't turn it off. I just used the kill switch as the headlamp switch. Works great and still have use of the hi/lo control. Although, I did sacrifice the kill switch, but I never used it.
TS
pushrod
« Reply #6 on: May 16, 2014, 07:19:05 pm »
TS
 Thanks for the tip Flyboy, I was gonna do that if all else failed but I managed to get it working with the new switch, wahoooo!
Pushrod
pushrod
« Reply #7 on: May 16, 2014, 07:33:41 pm »
Finally after two days of screwing with this thing, I managed to get the non US import switch to work. Now I am in control of my own destiny (and Bullet lighting) the way God and freedom loving people everywhere intended! LOL.
Pushrod
