So I bought the spiral bound "Work Shop Manual" from this website and it has alot of info but it is also very confusing. The section on drive chain adjustment is very confusing if any one can recomend a beter one let me know. The main reason I am upset with the manual is on pg 77 it gives an excellent exploded veiw of the carb for both 500 and 350cc's but only one problem there is no description of the parts only numbers beside them. The section on setting idle says to
1. turn pilot air screw down to the bottomw and reduce engine RPM to slowest rate using idle adjusting screw
2. open air screw and raise RPM to max
3. now adjust idle with idle adjusting screw.
This seems very easy but I don't know where these screws are. I've found two of them one that sticks out of the side with a spring around it in the middle of the carb (idle adjust I assume)
and one back by the air cleaner at a angle. (I have no Idea)
I also can't find the third one.
Thanks
