Ace, It's positively the gearbox. Stripped down the primary innards to access each shaft. Crank end is tight, trans shaft has play. Not terrible, but definite movement.
Would this be a countershaft bearing on the primary side? Is there a mainshaft bearing in the gearbox?
How should I go about continuing to diagnose this? I'm concerned I may get too deep...should this be done at a shop by someone with trans experience? Or is this not too difficult? I will be receiving (hopefully) the RS shift kit in a week or two, once our host receives, so I'll be getting into the gearbox side soon.
Thanks for the help!
Tim
