EFI Clubman
May 02, 2016, 03:18:17 am
Author Topic: Need throttle cable for 32mm Mikuni carb  (Read 375 times)
dmerc
« on: February 08, 2015, 06:07:55 pm »
 My cable is missing.  Are these the same as the stock Enfield cable or is it different. If so is the cable available here?
Re: Need throttle cable for 32mm Mikuni carb
« Reply #1 on: February 08, 2015, 06:13:08 pm »
You can use a stock cable, but it is a tight fit for length.
rvcycleguy
« Reply #2 on: February 08, 2015, 10:09:59 pm »
Where did it go missing?
dmerc
« Reply #3 on: February 09, 2015, 08:32:33 am »
Well, you know. Buy a bike that has all the small bits in a box. Lots of things missing or installed wrong. It's all part of the fun!
Hondo
« Reply #4 on: February 25, 2015, 12:29:59 pm »
My first two bikes were bits in a box!  I learned more about bikes from those two than all the others I've owned combined!
mikail gransee
« Reply #5 on: February 28, 2015, 12:24:58 pm »
 Try Hitchcocks Motorcycles, their awesome!
http://www.hitchcocksmotorcycles.com/home
-"ONCE YOU STOP CONTRIBUTING, YOU BEGIN TO DIE",   -ELENOR ROOSEVELT
1999 Enfield Bullet
1977 Yamaha xs360 TD
1978 Yamaha xs 400 D
2005 Yamaha YZF 600R
2007 Honda CBR 1000RR
dmerc
« Reply #6 on: February 28, 2015, 03:48:53 pm »
I ended up ordering the cable that sudco sells with their 32MM kit for the Enfield. Had to make a little bushing but it all worked out.
