End of the Road
May 29, 2016, 12:58:18 am
Author Topic: Higher lift with stock cams - a possibility?  (Read 2323 times)
da punds
  • Fireball 25
  • One of Britain's most northerly Bullet fans
Re: Higher lift with stock cams - a possibility?
« Reply #30 on: May 15, 2014, 12:24:52 am »
Hi,
although not using the shotgun rockers, I have roller ratio rockers in my big head, I run mine on the loose side, I can just detect a bit of vertical movement. This seems to be a good balance and is not really noticeable over other engine noises.
Kevin
56 Trailblazer Gemini, Super Fireball BigHead, 59 Clipper 570, 39 Model CO + others(BMW, GasGas, Yamaha, Suzuki (rare GSXR-750R)), Mk1a Interceptor project.
« Reply #31 on: May 15, 2014, 07:29:00 am »
Kevin,
Loose is good for your rockers.
.0045" cold lash would be the "neutral setting" for your rocker ratio.
Regarding noise, rockers just like ours are routinely run in racing cars and hot rods at .020" lash, so no real worries about beating anything up from lash.
But, if you prefer it where you have it, by all means,  use that setting.
BTW, have you checked your compression to see how much it was with these rockers? I remember one comment about low rpm torque when you were setting up your SuperTrapp exhaust. This rocker ratio can lower dynamic compression, and your torque may benefit from removing some of the gasket thickness under the barrel.
« Last Edit: May 15, 2014, 07:32:23 am by ace.cafe »
