brothers from other mothers
28 Guests, 3 Users
JohnDL, Ice, Rattlebattle
November 28, 2015, 04:22:30 am
Author Topic: Heavy Duty Alternator installation dilema  (Read 360 times)
« on: May 06, 2014, 09:41:19 pm »
The heavy duty alternator rotor does not properly fit onto the crankshaft due to its width being more than that of the stock alternator rotor. Where can I find the appropriate crankshaft sleeve/ alternator rotor spacer / washer, or what ever other name you would want to call the piece. I can find a replacement for the original, which is sold abundantly online, but the NEW alternator rotor spacer/washer that works with the heavy duty alternator has been too elusive for me to find. Have you successfully installed a heavy duty alternator, and if so, did you have a similar issue? Did you find a solution?
Any and all advice is met with gratitude.
