I purchased the Nfield Gear (C5 / B5) 5 pack Oil Change Kit #Z91499 for my C5 Military and found I had not needed the small copper washer 5/8" OD X 5/16" ID (p/n 144600, and the small 3/8" o-ring (p/n 500621). Are these for the B5, or did I miss something?
I am using Motul 15w/50 Semi-Syn 5100 / 4T Ester.
Also, having followed the service manual and owner's manual instructions tipping the motorcycle side to side with both the magnetic drain plug, and the sump assembly remove, I expected to refill with about 2.5 quarts of oil, but it only took a little less than 1.9 quarts to reach the max line. I did soak the oil filter so that would account for about .1.
I rode it for a few miles, shut it down, waited 2 minutes, and it remained at just below max.
