HAHAHA !! No... no complicated calculus or Chinese arithmetic needed ! Excellent work Singh ! See that.... Now we all know what the readings should be if we suspect a problem with the rollover sensor. Outstanding ! No Voltage change when flipped.... bad sensor. Pretty cool. What do you think Singh ? Some kind of variable resister in there , Like the map sensor ? Like I said, I could hear movement of some sort in there, did you hear it as well ?
I hear that too. Kind like a ball rolling, I thought it was actuating a switch.
Is the increase in voltage linear or direct?
It did not show linear change in voltage proportional to change in angle. Instead it jumped from one reading to another - from lo voltage to high voltage and
vice-a-versa. It only senses two positions - like the narrow band oxygen sensor on RE.
On the other hand TPS and MAP sensors respond progressively with change in throttle position and air pressure in manifold, respectively, producing linear response curves.
There were construction crew noises around me that drowned any low sound and I was turning it slowly to see gradual angular changes in voltage so did not hear rattle inside. But from everything we know and from your observations, there has to be something moving from one side to another that alters its output voltage.
PS - Anything RE, it has to rattle
