My 96 Bullet 500
28 Guests, 4 Users
Narada, cafeman, Ice, BeezrGeezr
May 25, 2016, 11:53:41 pm
Author Topic: Front Disc Brake Piston Cylinder and Seals Service  (Read 400 times)
« on: April 26, 2014, 04:15:53 pm »
For sometime the front brake pads were holding on to the disc. The brake pistons were not retracting. This affected riding and turning since the brakes were always ON for the front wheel.
Took out the brake pistons. Its cylinder walls had hard crud (looked like rust) accumulated over the years due to perhaps snow and salt and other debris. The pistons had white crust on surface too. All this prevented free movement of one (top) piston.
Each cylinder has 2 seals - a larger piston seal and a smaller dust seal.
After service, it is working very well.
https://www.youtube.com/watch?v=3W1K6Normn4
« Last Edit: April 26, 2014, 04:34:39 pm by singhg5 »
Re: Front Disc Brake Piston Cylinder and Seals Service
« Reply #1 on: April 26, 2014, 04:31:37 pm »
THANKS VINCE for your GOOD ADVICE before I opened caliper !!
Some pictures
« Last Edit: April 26, 2014, 04:59:34 pm by singhg5 »
« Reply #2 on: April 26, 2014, 04:50:32 pm »
Thanks for another good video Singh. :)
Sectorsteve
« Reply #3 on: April 26, 2014, 06:46:17 pm »
I really need to do this too...
