Author Topic: Philips H4 Xtreme Vision  (Read 3252 times)
NorEaster
on: April 25, 2014, 11:24:22 pm
In reading a previous post about brighter headlights for our bikes, the Philips H4 Xtreme Vision bulb was mentioned.
Am I understanding that it just pops right in and the present connectors fit right on?
Also, is it a whiter light? I picked up a pair of the LED pilot lights but they are quite bright and white. They look out of sorts with the OEM head lamp.
Thinking if I could find a brighter white head lamp I'd opt to put the LED pilot lights in too.
Any info is appreciated
Reply #1 on: April 26, 2014, 01:37:58 am
If you are in the U.S. you will need to replace the sealed beam assembly that comes stock on the bike.   After installing the 7 inch conversion kit and glass, then, you can replace the bulb with whatever will fit into the glass you install.
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
Reply #2 on: April 26, 2014, 04:43:25 pm
Mine is an Adjure tripod diamond cut unit. I use a blue Xenon bulb (Ebay from China) & blue LED running lights. See Pix.
Best Wishes, Craig McClure
NorEaster
Reply #3 on: April 29, 2014, 12:34:36 am
I'm tempted to use the orange lenses but would then want to rig the wiring of the pilot lights to work with the blinkers
Reply #4 on: April 29, 2014, 04:13:04 am
easy to do.  the tigereyes are easy to rewire.
I like the yellow-ish light, reminiscent of a 6 volt system.  So, I run a 35/35 watt tungsten filament BPF bulb inside a heavily fluted glass lense.
meph1st0
Reply #5 on: April 30, 2014, 04:05:27 am
I have Philips Xtreme vision 60/55. It is a direct replacement for the stock bulb. It is better than stock and high beam throw is good. No it is not white light. But if you are looking for touring, a nice set of aftermarket led lights are better.
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle
Singh_Chicago
Reply #6 on: April 30, 2014, 07:40:41 pm
olhogrider
  • Classic 350 Desert Sand
  • Blue Ridge Mountains of NC
Reply #7 on: May 02, 2014, 03:24:31 pm
I have this on my G5
http://www.youtube.com/watch?v=v38uVZQQ1kA
Nice pictures. So what is it? Part #? Where did you get it and what was required to install it? Thanks.
