My 350 Classic
August 02, 2015, 08:40:50 pm
Author Topic: Play in the clutch basket!  (Read 472 times)
kylohere
« on: April 25, 2014, 01:11:14 am »
Okay, so I'm working on a friend's Bullet Standard 350 cast iron and on opening the primary cover, found a lot of side to side play from the clutch.
Tightening the centre nut didn't help much and so I went on to get the entire clutch case off the bike. The nut on the primary sprocket was found to be loose, and on tightening it, the play has reduced.
However, the clutch bell itself still has a lot of play when mounted on the centre. On removing the retainer clip, it was found that the centre race, on which the balls roll, was devoid of much visible wear - just some dark marking but absolutely no ridges.
My manuals don't say anything about this and my older Brit bikes don't exhibit this much play anyway. My question is if this play is normal and if so, then how much is too much.
Thanks in advance!
Chasfield
Re: Play in the clutch basket!
« Reply #1 on: April 25, 2014, 09:59:43 am »
With the springs and plates removed, I think the clutch basket is always going to flop around quite a bit. You will have noticed that the back of the basket carries a riveted friction lining and this bears against the flange of the clutch centre as the basket flops down under gravity. This effectively gives you an extra plate pair for free, at the expense of the clutch never fully disengaging. Better if this thrust bearing surface was made from bronze.
2001 500 Bullet Deluxe
« Reply #2 on: April 27, 2014, 07:50:49 am »
My clutch does the same thing.  You look at it and you can grab the basket and literally move it around side to side about an 1/8" in any direction.  You are correct about the the play being in the ball bearing mounting flange in the basket and the clutch hub in the mating area itself.  As far as I know the only cure is to replace it with a belt drive.  I personally JUST rebuilt my entire clutch about 3 weeks ago.  New friction plates, new steel plates, new basket inserts, new springs and new bearings.  Even with all of the sloppy play in there, my clutch works great with no issues.  Just don't use Advance Auto Parts brand Type F ATF fluid in the primary.  Something about that stuff caused my clutch to slip very badly.
Scottie J
kylohere
« Reply #3 on: April 27, 2014, 01:41:58 pm »
Thanks for the replies guys but the malaise seems to lie deeper within.
On assembling the entire clutch assembly, I still had a gut feeling that it wasn't right. On kicking the engine over, the basket seem to oscillate in and out and I stripped the damn thing back down.
It seems the entire shaft on which the clutch bell rides is moving about 2 mm in every direction I yank it.
I reckon I need to pop the gearbox open to have a look? Worn bushes? Worn main shaft and/or main shaft sleeve? What do you guys think? And would I need to drop the engine and gearbox off the frame?
« Last Edit: April 27, 2014, 01:47:57 pm by kylohere »
« Reply #4 on: April 27, 2014, 03:03:45 pm »
You have two bearings on that shaft. Check the one in the end cover (small bearing) for damage and then check the large bearing (sprocket side). If they need replacing, use sealed bearings so you can use gear oil. You should be able to replace the main shaft bearing (large) with the gearbox in place. You will have to remove the outer primary case to remove the gearbox sprocket. While your in there you should also check the lay shaft bushing. I think Hitchcock's sells a complete rebuild kit with all the parts needed.
2009 HD FLHTPI Police 103
« Reply #5 on: April 27, 2014, 03:25:20 pm »
My whole shaft wobbles the same way too.  I'm not too worried about it for now.  I won't do anything about it until I rebuild the tranny with the close ratio gears.
Scottie J
