sherry punjab
14 Guests, 2 Users
kodai, DanB
February 13, 2016, 01:12:44 am
Author Topic: Oil filler plug on my left uce case?  (Read 447 times)
hogdad
  • 2012 C5 Military Special
« on: April 24, 2014, 03:55:55 pm »
Why does the uce left case have an oil filler plug?
I thought the entire lubricating system (engine, clutch, and transmission) was filled from the right case filler plug.
Does the primary chain in the left case sit in an oil bath?
If so, is it fed from the main sump or is it separate?
2012 Royal Enfield C5 Military
2009 H-D Road Glide FLTR
2003 Triumph Bonneville T100
2000 H-D Electra Glide
1980 H-D FXS Low Rider
1979 H-D XLS Roadster
1978 Triumph Bonneville
1969 BSA Lightning
1966 BSA Lightning
Ragmas
Re: Oil filler plug on my left uce case?
« Reply #1 on: April 24, 2014, 04:05:51 pm »
That is an inspection plug.  It also aides in removing that case side if you have the proper tool.  You could put oil in there but it is not necessary.  Leave it closed.
Samgar
2009 G-5 Military
Little Falls, NY
« Reply #2 on: April 26, 2014, 07:20:20 pm »
the primary chain runs in the same oil as the rest of the powerplant.
it is fed by the main sump.
the left plug is used to inspect slack of the primary chain.
having said that, I suppose it could be used to refill the sump following a filter change.
