Gandhi Bhawan
May 31, 2016, 04:55:15 pm
Author Topic: Fork Seals  (Read 318 times)
cafeman
Fork Seals
« on: April 24, 2014, 10:57:19 am »
2001 Bullet, need fork seals. Who has sourced them from Honda, Yamaha, Kawasaki, Suzuki etc shops? Don't want to walk in and go through the usual "what's it going on"......Just need any particular make/model that are the same.  Thanks....one leak leads to another! :o
« Last Edit: April 24, 2014, 10:59:34 am by cafeman »
                     1996 Yamaha Seca II
                     1991 Husqvarna 350WXE
                     1991 KTM 250MX
                     2004 Husqvarna TC450
                     1995 Honda VFR750
boggy
  • Karma Ultra: 7
Re: Fork Seals
« Reply #1 on: April 24, 2014, 11:18:36 am »
Ordered mine through NField gear.  If the fork legs are anything like the AVLs you will also need new crush washers for the fork studs stick out of the legs (where you drain the oil).  Those, I did have to get from a shop.  I ended up with Yamaha washers and they weren't cheap!  There are other places to source the washers - I just needed them that day.
2007 AVL
2006 DRZ400SM
