Color Concepts
24 Guests, 4 Users
kayak65cuda, ace.cafe, Ice, Guaire
April 29, 2016, 08:31:23 pm
Author Topic: Premium fuel  (Read 2171 times)
dginfw
Re: Premium fuel
« Reply #15 on: April 24, 2014, 11:06:37 pm »
+1 on using an additive when running ethanol.  By now, most of the country is using ethanol....for reasons which are purely political and financial.  On engines that are designed to run straight gas, ethanol lowers power and fuel economy,  plus it raises the cost to consumers.
Dave in TX:   '01  W650- keeper
                    '12 C5 military -sold
                    '14 Continental GT-  sold
                    '06 Iron Barrel Bullet- Ace Clubman mods
Re: Premium fuel
« Reply #16 on: April 24, 2014, 11:15:09 pm »
About the only fuel we can get at a filling station here in Arizona has 10% ethanol in it.
All of the local filling stations have 87, 89 and 91 octane.
Being a low tech engine I've had no problem using the 87 octane around Phoenix.  No pings. Runs smoothly and gives me a little over 70 mpg (US gal).
When I make my trip up to Flagstaff where I'll be climbing 7% grades I do fill up with the 91 octane fuel just to be on the safe side.  (Running with a wide open throttle to maintain 50 mph for over 5 miles without stopping does heat up the engine a bit and I think the higher anti-knock fuel gives better protection under these conditions.)
Barnone
Re: Premium fuel
« Reply #17 on: April 25, 2014, 06:13:14 am »
Wonder what cylinder heat temperatures you will be getting on your run to Flag?
I have this CHT gauge on my DF and Ural to watch the temps.
http://www.ebay.com/itm/Trail-Tech-TTO-Temperature-Meter-Black-Digital-Gauge-14mm-Spark-Plug-Sensor-NEW-/380890308908
Vince
2001 Kawasaki W650
2012 Ural Yamal
2012 DF250RTB
Fort Myers,FL or Robbinsville,NC
Re: Premium fuel
« Reply #18 on: April 25, 2014, 07:27:43 am »
I have never experienced any of the problems from Ethanol that some of you seem to have experienced.  I've seen some nasty sludge in different carbs before, but I've never seen gas tanks fall apart or fuel lines rot out because of it.
Scottie J
Re: Premium fuel
« Reply #19 on: April 25, 2014, 11:31:18 am »
The only problems I've had were some bubbling of the paint inside the tank and around the filler neck and the cracking of the exterior layer of the fuel line early on.  To be fair, some bikes come out of the crate with the fuel line cracked.
Bubbling paint around the filler necks is another problem seen out of the crate.  I saw it on a batch of '11 - '12 vintage RE's at a dealership...
suitcasejefferson
Re: Premium fuel
« Reply #20 on: April 25, 2014, 03:49:37 pm »
I recently rode up to Forest Lakes (east of Payson) and used 87 octane. Rather than try and maintain 50 mph in 5th gear, on some of the long steep grades, I downshifted to fourth and went about 40 mph. I don't like the idea of using full throttle for more than a few seconds at the time. Two lanes in the same direction, and I was not in a hurry.
Craig McClure
  • Riding over 50 years
  • "No Future In Getting Old"
Re: Premium fuel
« Reply #21 on: April 26, 2014, 10:52:07 am »
Trust Me, The EFI engines are made to run on the lower octane gas. If you use STABIL MARINE formula fuel stabilizer, it counteracts the negative effects of Ethanol. The Experts say you can run high octane, but are wasting your money. Running any single cylinder engine you can close the throttle occasionally to insure oiling the upper end, but probably don't NEED to.
Best Wishes, Craig McClure
suitcasejefferson
Re: Premium fuel
« Reply #22 on: April 26, 2014, 11:13:33 am »
The bubbling paint was an issue on my 2013. All of it is gone now, and some of it fell down inside the tank. What came off around the filler was not enough to plug up the fuel pump filter, but I am still concerned because it looks like the entire inside of the tank is painted. Some paint can resist ethanol for a long time, but it will eventually began to soften and come loose.
Those dirt bikes were several years old, and had probably had ethanol in them the whole time. The plastic was not melted, just badly cracked all over. I have other plastic and rubber melt.
Supposedly marine grade Stabil will help, but I haven't found any actual proof yet. Ethanol is some nasty stuff, and just doesn't belong in motor vehicles.
A little off topic, but I was watching this weird video on Youtube, these 2 guys were customizing a car. They wanted it rusty. They stripped off all the paint, then soaked it in beer. It rusted very quickly.
trimleyman
  • 1953 or 2011.
Re: Premium fuel
« Reply #23 on: April 26, 2014, 02:17:00 pm »
I tried 91 octane when new and did not notice any improvement over 87 so have stuck with ARCO 87 ever since. Now I am in the SF bay area so we have that special California gas with the extra additive for cleaner emissions.  I understand it's technical name is BS (comes from cattle I am told) and requires an extra 20c per gallon pricing.
Then:-
1978 Ducati 900 GTES
1969 Ducati 350 Desmo Racer
1965 Triumph Tiger Cub 200
1967 BSA Bantum
Candoman
Re: Premium fuel
« Reply #24 on: April 26, 2014, 04:28:15 pm »
I store my bikes with premium gas and Stable. I was told that premium had less ethanol in it. However, I don't know this is in fact true. I normally run regular gas and can't say I notice any difference in performance.
2012 Royal Enfield C5 Chrome
2009 Yamaha Zuma 125
2006 Suzuki Burgman 650
Re: Premium fuel
« Reply #25 on: April 26, 2014, 07:31:43 pm »
What it really boils down to is unless you are running 10:1 compression or higher OR you run a lot of advance on your timing AND/OR you flog your bike on a regular basis    ;D    premium fuel will do nothing for you besides spend your money.
Scottie J
AwL
Re: Premium fuel
« Reply #26 on: April 27, 2014, 05:10:11 pm »
Here's a website that lists gas stations all over the US that have ethanol-free gas.  al
http://pure-gas.org/index.jsp
bob bezin
  • I ride therefore I am.
Re: Premium fuel
« Reply #27 on: April 28, 2014, 10:19:04 am »
thanks. i found 93 right here in viroqua.
2015 indian chief vintage
65 500cctriumph
04 bonnie black
71 750 norton.
48 whizzer
