Gandhi Bhawan
May 01, 2016, 04:59:25 am
Author Topic: Bad Stator?  (Read 1663 times)
neil
  • Neil & Buzzy the Bullet
Re: Bad Stator?
« Reply #15 on: April 25, 2014, 10:28:31 am »
Azcatfan:
If your sure you need a new alternator, order it from Hitchcocks ! The shipping will be a large number but the item will be in your possession within 3 to 4 days. They airmail everything out side the UK.
Neil and Buzzy the Bullet.
Re: Bad Stator?
« Reply #16 on: April 25, 2014, 10:46:44 am »
Thanks Blltrdr!  I had read this but could not find it again in my searches.  Looks like Kevin said it needs to be at LEAST 50V/AC coming off of the two violet wires, and that even as low as 47 V/AC may not be enough to charge the bike.  Thats good to know because the highest I have seen was 35 V/AC with the motor revved up.
One thing I did not do was check resistance of the violet wires.  I'll do that when I get home from work.
I am now sure that the Alternator is bad, but I'd sure like to know why.  I know vibration and all, but there's always been good fluid in there, and even though the bike is 12 years old, it has less than 5k miles.  During the interum waiting for an alternator, I'm going over the harness with my multimeter as a fine toothed comb.  Check any work I've done, patchup and secure any potential abrasion areas for the wires, dielectric grease on all connectors, make sure they're tight and all that good stuff.  :o
Electrical parts wear out period! I wouldn't worry to much on why it wore out unless you think you had done something to perpetuate the problem. These bikes do generate a lot of vibration which can be a killer on electrics. One thing to think about is you are getting voltage, just not enough. Your problem could be that your rotor is not as magnetized as it was when new. An electric motor shop in your area could re-magnetize your rotor for you or you might be able to go online and find a how to video. I would try that before spending the bucks on a new stator. Once you pull your stator and rotor off you can check the rotor by taking a large screw driver and attach it to the rotor and lift it up. If the rotor doesn't stay attached to the driver it needs to be re-magnetized.
2009 HD FLHT Police 103 6 spd
azcatfan
  • 2002 Bullet ES
Re: Bad Stator?
« Reply #17 on: April 25, 2014, 12:17:53 pm »
Azcatfan:
Thanks Neil, that's good to know.  I like to buy from our host whenever possible, but in this case they don't show an alternator for my model.  Everything they have for an Iron Barrel is the KS model.  Thank you for the Info, Hitchcock's has a good reputation too.
The magnet fealt pretty strong actually, even before cleaning it took a bit of force to move the stator around while I was taking it apart.  I'm pretty sure that the magnets could have held a fairly heavy wrench if I'd chosen to place one there.
I also agree that the vibes and heat can kill a small alternator like this one, but I figure it won't hurt to go ahead and clean up any other potential electrical problems.
Thanks for all the help!
azcatfan
  • 2002 Bullet ES
Re: Bad Stator?
« Reply #18 on: May 06, 2014, 06:45:24 pm »
Question:
Do the violet wires on the new stator replace the red and black wires on the old one?
Seems simple, with the Old Stator:
Red connects to the Violet in the harness
Black connects to the second Violet in the Harness
Orange to Orange
Yellow to Yellow
Seems to reason that the New Stator:
Violet to Violet
Violet to Violet
Orange to Orange
Yellow to Yellow
Is this right?  :-\
Re: Bad Stator?
« Reply #19 on: May 06, 2014, 06:53:15 pm »
Sounds sense-able to me.
More than black to violet and red to violet does.
azcatfan
  • 2002 Bullet ES
Re: Bad Stator?
« Reply #20 on: May 06, 2014, 09:03:32 pm »
UPDATE
It is indeed that simple, and I am a happy camper!  Back on the road and fully charging!   8)
Final Outcome:
Stator was bad - 20-30 V/AC across the violet wires prior to Rectifier at high RPM, 6-10 V/AC at idle.  Charge in V/DC at the battery was 0 at idle, 0 at high RPM.
New Stator - 45-47 V/AC across the violet wires prior to Rectifier at high RPM, 13-13.8 V/AC at idle. Charge in V/DC at the battery is 12.8 at idle, 14.4 at high RPM.
One Happy Camper  ;D
Re: Bad Stator?
« Reply #21 on: May 08, 2014, 11:30:59 am »
Awesome!  Glad to hear!   :)
Re: Bad Stator?
« Reply #22 on: May 09, 2014, 05:50:20 pm »
I didn't see anything in here about having a bad rotor. if all the wiring is checking out in the stator, the rotor might well be down on magnetism. The rotor can be remagnetized an an auto electric shop. Bad rotors are somewhat unusual, but definitely not unknown. I replaced several rotors when I was working in a Brit bike shop.  Get yours checked out, or get a new one.
