Mt ride 2
20 Guests, 4 Users
Ice, skyfli, mattsz, Otto_Ing
August 02, 2015, 04:35:02 am
Author Topic: all fired up!  (Read 431 times)
devon john
all fired up!
« on: April 21, 2014, 11:22:00 am »
today i fired the Bullet up for the first time, but the barstool was kicking back hard.
i have fitted pazon eletronic ignition is this a little to advanced? set at 34deg before TDC
running a Amal 32mm carb +Henry Price R cams , big valves , high out put oil pumps plus roller bottom end.
harley Dyna 1550
harley FLH 80
535 Royal Enfield bullet
Re: all fired up!
« Reply #1 on: April 21, 2014, 12:02:06 pm »
34o should be about right in full advance. Are you sure you timed it to the advance position. If you put the retarded timing there, it will definitely try to bite you!
It should be about 9o retarded
Re: all fired up!
« Reply #2 on: April 21, 2014, 05:32:03 pm »
No decompressor used? Is it kicking back at you, or is it just running backwards?
« Last Edit: April 21, 2014, 07:36:59 pm by cyrusb »
devon john
Re: all fired up!
« Reply #3 on: April 24, 2014, 01:12:43 am »
a mate came around with a strobe ,we timed it to 34deg(i was way out) its running really well and starts first kick!!
need to get some miles on it now!
john
harley Dyna 1550
harley FLH 80
RE_Chief
Re: all fired up!
« Reply #4 on: April 24, 2014, 03:39:24 am »
Nice one, have fun.  I am sure you will.
Regards Charles
1955 Indian Tomahawk 500 twin
1958 Indian Chief 700 twin (SMPB 9002 the 2nd ever made)
1960 Indian Chief 700 twin
1964 Interceptor Mk1 750 twin
1967 Interceptor Mk1A 750 twin
1994 Bullet Deluxe 570 long stroke single
