She is at about 4000 miles right now and I know its probably time for a few new things.
I'm thinking Chain, all new cables, and a full fluid change. Anything else you guys might suggest?
Sir,
Full fluid change is the first thing that you should had done after buying the bike; it helps you to get a status of everything and to reset the oil change clock.
Cables can be tricky to replace so do a good inspection of them and how they are routed. Also buy a can of cable lube and lube them up good!- The biggest failure with cables is binding and breaking/stretching from friction because they are dry.
The chain is a very important part of your bike. 2 things I do to see when replacement is required is if the adjust indicator on the wheel has been past, then you are doing damage to your sprocket (if the teeth are sharp than the chain is rubbing-very bad)
and when you spin the rear wheel and check tension, and notice that some spots are really loose while others are tight-then you have uneven stretching and this will give you a jerky ride; a old trick to add speed to your bike when you do replace the chain is to get a rear sprocket with more teeth!
Valve adjustment is very important and will help make starting your bike easier. If you can kick through a compression stroke, your valves are too loose. You should be able to place full body weight on the kicker and it will hold. One thing I do to help those valves stay well is to add a little
LEAD Substitute to the gas.
In summary-if you do not have a Manual, get one! it will save you in the end!
