While waiting for my RE to be delivered, I ordered an EFI pipe and K&N filter. Once the bike was delivered, the stock pipe was used for about a week. I changed the pipe first. The difference is there and you can feel it. The bike has better throttle response, accelerates and generally runs better with the EFI. My pipe in 200 miles has not yellowed, nor turned blue. Looks like the day I bolted it on.
The air filters were a bit different. No real difference in the K&N and stock that I could say I honestly felt. Again no discoloration on my pipe with this change. The bike's ECU adapted seamlessly so far. Air filters are an issue that is personal. I kept the K&N. Others choose not to use them. But the EFI pipe, though expensive was worth it in terms of weight reduction and performance improvement.
Will it last as long as stock?? I don't know.
Sound. Louder. With the baffle out it is loud. I rode 30 miles and put the baffle back in. Why, it gave me a headache even with ear plugs. Baffle in, I noticed no real difference in power over no baffle. Maybe a bit more torque with the baffle in. But that is subjective on my part. Power wise no difference. Acceleration the same. Headache is gone. It is loud enough to pleasantly sound like British motorcycle, but not intrusive. Excellent compromise.
Your muffler is part of the Indian quality control manufacturing epic. Poor quality welds and metallurgy in parts where you can scrimp. Add to this single cylinder vibration and ....bang! I have a friend who rides scooters, his two Stellas went great until 6000 miles, then gently began to fail. I think the RE is better than a Stella given the new manufacturing plant.
As for the pipe, if you have the money, buy one. It looks great on the bike. Perfect balance of style and sound. It is a straight bolt off and on after you remove the heat shield from the old muffler.
