Electra build 2010, May. The better sprag was fitted starting August 2010.
So I still had the weaker one, which failed at 12000km.
Chain was replaced at 11000 km with the O-ring chain from the classic, which means no need to swap the front sprocket.
Other replacements: starter solenoid.
Currently approaching 30000 km.
Tank started to leak at 24000 km at the rear bolt: no visible cause though, making welding attempts futile. Repaired it with soap and metal paste, assuming a replacement would come swiftly. Just got news: new tank is in (6 months, thank you). Boy, am I glad for soap: it's a tank-saver.
I read the reports about the 'improvements' with mixed feelings. I quite like the push and turn bulbs; and the glass fuses. Doing away with the rats' nest in the nacelle: now that's a good thing.
My daughter has a Honda which is dead reliable. I prefer my bikes, they live, don't see them as trouble.
