612cc kickstart-only Sixty5
May 03, 2016, 05:06:38 pm
Author Topic: Front chain case  (Read 584 times)
rvcycleguy
Front chain case
« on: March 30, 2014, 11:23:52 am »
I'm removing the front chain case to drain the oil.  When refilling with the fill hole, when it's full it runs slightly out of the small screw hole near the bottom of the outside cover?  Or do I fill it to the fill hole?
Re: Front chain case
« Reply #1 on: March 30, 2014, 11:25:14 am »
Fill to the small screw.  ERC
« Reply #2 on: March 30, 2014, 11:26:55 am »
+1  It's about 1/3 qt
rvcycleguy
« Reply #3 on: March 30, 2014, 11:31:49 am »
Thank you very much.  It did not drop much oil.  I was thinking it has more it in than that.  I guess it's not a complete oil bath, but more of a splash type sump.  Thanks,  RV
« Reply #4 on: March 30, 2014, 11:38:49 am »
Yeah it splashes more than it soaks, but it's more than enough.  Also, not sure what you're using in there but ATF works quite well, Type F in particular.
Scottie J
rvcycleguy
« Reply #5 on: March 30, 2014, 01:47:04 pm »
Thanks.  How do you count the chain link?  Sounds like a dumb question I guess...  I count 104.  I'm at the end of my adjustment and want to order a new one.
« Reply #6 on: March 30, 2014, 02:08:51 pm »
If it's a 1956 20 tooth sprocket is 88 pitches, if it's 25 tooth it's 90 pitches.  ERC
rvcycleguy
« Reply #7 on: March 30, 2014, 02:20:06 pm »
Thanks.  I was counting the rollers.
« Reply #8 on: March 30, 2014, 05:55:49 pm »
I count the side plates starting with the master-link.
rvcycleguy
« Reply #9 on: March 30, 2014, 06:25:05 pm »
Thanks Arizoni.  That helps me.
