190 cfm - That's about 40% increase over original. As per your previous postings this will give about 38 HP. Can I safely add another 2 HP for the 535 cc piston - bringing the total to 40 HP + perhaps a couple of HP from other modifications?
Since I have the hybrid Power Commander and cannot increase the rev limit should I be considerring to upgrade the 19T sprocket to a 20T?
Well, that figure would be a crankshaft hp estimate, and we don't really know how close those estimates will hold yet, with the UCE. Also, we will see some reduction when the throttle body and filter package get installed, probably 10-15 cfm lower. So, when considering the fully installed conditions, we will more realistically see probably around 175 cfm peak, in situ. That brings the installed flow/hp estimate to probably more like 35 crankshaft hp.
With the typical drivetrain losses that we have seen from Bullets in the past, we should expect somewhere between 5-6 hp less than that figure at the rear wheel, so let's estimate a more realistic figure of about 29-30 hp at the rear wheel. However, it could get better than that in ideal circumstances. We get more with the Fireball from the similar flow amount, so maybe we will get it here too. Much will depend on tuning it to best effect, and if the rpm range can be raised to get the most from the flow.
Regarding the added power from the 535, this added displacement will yield more torque at all rpms, and potentially more hp too, but the flow calculation isn't dependent on displacement. The flow calculation is based on how much power "could" be extracted from the flow level in best case scenarios, regardless of displacement. It is up to us to get the rpm and the tune-up necessary to make as much as we can from the flow. The flow is the starting point, but we can't get to where we want it to be without having that first.
Now that we know what the Continental GT 535 really is putting out in terms of power, we can make a comparison.
The stated crankshaft hp of the GT 535 is 29.2 hp.
Estimated drivetrain losses, let's say 6 hp estimated.
Resulting rear wheel hp estimate would be 23.2 hp for the GT 535.
Assuming that the Ace mods do yield the estimated 29-30 hp at the rear wheel as described above, then we are looking at about 7hp more than the GT 535 in comparison. About 27.5%-30%(estimated) more. And that's above and beyond the "hottest" and newest factory 535 package. It's more than 40% higher(estimated) than the factory 500 power.
Now, depending on how you want to look at this, you could say that it isn't exactly setting the world on fire, and that these are all just estimates, and maybe it might be lower, or higher. But it's a decent power level, and we are installing it on a stock bottom end. We have to be careful with this, so that we don't upset the apple cart, and have too much power for the stock bottom end to handle. The aim is for a more powerful ride that makes people happier with their riding experience, and doesn't break things.
With our currently experimental rocker system, it should be quite simple and reasonable to upgrade to higher performance by just using a higher ratio rocker, as long as there is clearance for the valve/piston over TDC, and the ECU can be adjusted to suit the new conditions.
So, if it turns out that the UCE bottom end is very sturdy and can handle more power, we can give it more power. And we plan to keep all the work in the cylinder head if we can, so that users won't have to remove the engine and rebuild internal parts, if it's possible. That part really isn't up to us. It's whether the factory built enough strength into this platform to withstand it.
Regarding your hybrid-PC, and the rev limiter, we are going to need to see where the hp peak is going to be. The 535 will help to keep that hp peak lower than the 500 would be with the same port, because of the higher demand of the added displacement. That will work in your favor. Also, the torque will be higher at all rpms because of the added displacement and bigger bore. That will work in your favor. As long as we peak below your rev limiter rpm, then you can gear it as you like, and still access all the hp available.
