Geichals' Bull
May 01, 2016, 04:58:01 am
Author Topic: Sealed Battery  (Read 1903 times)
Bankerdanny
Sealed Battery
« on: July 11, 2008, 04:08:25 pm »
FYI for Classic Bullet riders, the sealed battery CMW sells has a few differences from the standard  battery:
1. The poles are reversed
2. The battery is slightly larger than stock (but does fit in the stock box).
These two things combined means that (a) you need to relocate where the ground lead attaches to the frame and (b) the positive lead will short out against the frame unless you shim the battery box out by 1/2 inch or so.
Not a big deal, and the battery works great, but the differences caught me by surprise.
Endeavor To Persevere
scoTTy
Re: Sealed Battery
« Reply #1 on: July 14, 2008, 10:16:55 pm »
yep i made mention of that some time back...  lucky we had enough wire huh?  to make it work... yes?
Bankerdanny
Re: Sealed Battery
« Reply #2 on: July 15, 2008, 09:45:04 am »
I relocated the ground wires to the bolt that holds the battery box to the frame.
