I just read thru that thread that 1 Thump posted. Here's my 2 cents:
Certainly this can be done. ANYTHING can be done with the right resources, the right amount of money and the right motivation. Tho there are several points that were brought up in that thread that need to be considered and addressed......
- The most important being engine mounting. The upper head stays are
CRUCIAL on these motors. I know for a fact that if you run one of these twins without the head stays, it will damn near shake you right off of the bike. I learned this last summer after replacing the head gaskets and taking a short 20 minute ride to get the motor to operating temp to hot torque the head bolts. It was so bad I don't think I revved over 3500 RPMs.
- Another consideration is going to be that rear wheel alignment, you will most likely need the rear wheel that came with the motor and trans.
- Next, keep in mind that any time you put a motor where it doesn't belong, you are guaranteed to need some amount of custom fabrication. It's almost impossible to say what exactly as there isn't much info on this conversion. So unfortunately, you will have to Pioneer what needs to be done, unless you can get in contact with a person that has already personally done this.
Finally - The hardest part. Actually FINDING a motor and trans. How hard is this? Well, I spent about 2 1/2 months searching damn near every day for just a motor. I was wanting to build a race motor for the Blackhawk that I could build and just drop in 1 weekend. I came in contact with 1 individual that had/has an Interceptor Series I motor and trans. The motor needed to be rebuilt and the guy still wanted $2K. No thanks, I'll pass on that deal. I finally came across a deal where a member here on the forum had a '59 RE/Chief. The bike was completely disassemble and had spun a rod bearing on cylinder 1. I ended up getting the entire project for the same price that I wanted to spend on a motor. So now I have found myself building a whole new bike.
I guess what I'm trying to say is, unless you are very handy with custom fab and have access to the resources you need, I would find yourself an entire bike with a twin and just restore it. Honestly, there is hardly much of a difference in the frames, but there are enough differences to cause a few issues.
And FWIW, the late model 700 ('58 on) motors are essentially the same motors as the Series I Interceptors. It is very easy to turn a 700 into a Series I, that's what I'm doing anyways. With the addition of a supercharger of course.
Scottie J
