Bullet 500
April 30, 2016, 03:46:52 pm
Author Topic: 692cc gasket set...Constellation=Trailblazer=Chief?  (Read 580 times)
bullethead63
« on: March 21, 2014, 08:52:09 am »
Here's one for Rotorwrench,ERC,Carlo,and Tom 60 Chief...will a gasket set for 1959-1963 Constellation work for my 1959 Chief?Same engine,as far as I can tell...thanks to anyone who can clear this one up...
Bullethead63~
Re: 692cc gasket set...Constellation=Trailblazer=Chief?
« Reply #1 on: March 21, 2014, 10:53:37 am »
I believe they are the same gasket set.  Well, at least I put the gasket set that came with my Chief on my Trailblazer.  Not sure what size bore you have, but make sure the head gaskets match your bore or you'll have piston clearance issues.
Scottie J
RE_Chief
« Reply #2 on: March 21, 2014, 04:18:10 pm »
Hi bh63,
The Chief motor is a Super Meteor motor, so the question is will a gasket set from a Constellation fit a Super Meteor motor?  My guess, and that is all it is, is it will be compatible in most places but may not be correct everywhere.
Regards Charles
1955 Indian Tomahawk 500 twin
1958 Indian Chief 700 twin (SMPB 9002 the 2nd ever made)
1960 Indian Chief 700 twin
1964 Interceptor Mk1 750 twin
1967 Interceptor Mk1A 750 twin
1994 Bullet Deluxe 570 long stroke single
« Reply #3 on: March 21, 2014, 06:25:54 pm »
To the best of my knowledge the only difference was camshafts and gearing.
Scottie J
« Reply #4 on: March 21, 2014, 09:01:01 pm »
The gasket set will fit all 700 twins. You'll need the right seal set for your motor. The old ones use felt seals. The Chief uses rubber seals.  ERC
bullethead63
« Reply #5 on: March 22, 2014, 12:31:36 am »
Thank you,Scottie,Charles,and Roger...you guys are the BEST...I'll go ahead and buy this gasket set,and make it work...big RESTO thread is in the works...Matt Law/Bullethead63~
