Hot in India? The weather heat is not the problem it's the engine heat. In India there not going as fast as us in the states(we have more open rodes) And they go by kpm not mph.
Huh??? you would have a lot harder time over heating a Bullet in the dead of winter in Michigan... I've had a temperature gauge on my oil tank for years now and I can tell you this- normal oil temperature in the tank will be twice the outside air temperature.
EXAMPLE-
if it is 70 out; the tank temp will run 140...
if it is 90 out; the tank temp will run 180...
I have never seen 200 or higher which means It doesn't get to 100 degrees here in Illinois very often.
KPH... you may be onto something... I'm going to get one of those SMITHs english
speedos that read in KPH... it will have the look I want and my bike will run cooler...
just thinking out loud... Mike in central Illinois
