I have checked the inlet mountings for leaks before. But will check again. I haven't checked the inlet mountings today. The exhaust is sealed in. I have tried the P2 and it cuts out the same whilst riding, even worse. I didn't get as far. My bike is now down to reserve. So I may completely empty it and make sure it is clean. The flow of fuel is still good.
I have tried putting in the stock needle jet P0.8. Now the bike revs up real high from starting. No matter how you adjust the throttle stop screw or the mixture screw.
The needle jets have been hard to get in or out. I am wondering if the carb body is warped or something! Now the slide gets stuck up as well. I've never had so many issues in one go with a carb!
The slide doesn't move around in the body.
On my last RE before this one. The Mikarb was a nightmare. Last time I changed it for a Amal Monobloc. Which was reliable and did give an performance increase thanks to the bigger aperture.
So guys I have decided, time to ditch the Mikarb. Game over...Unless you think I should keep trying to get it right?
The tappet adjustment was checked today.
The air filter I use is a S&B pancake air filter.
So do I go with a TM32? Or an Amal Monobloc, MK1 concentric premier, Or MK2 concentric?
