Raj...2
50 Guests, 3 Users
krimp, chuychacon, mtrue77
May 27, 2016, 09:17:33 am
Author Topic: '06 Military  (Read 12397 times)
little_a_o
  • 8 mph slower than indicated
  • '06 Military (Missed)
'06 Military
« Reply #15 on: August 15, 2007, 10:14:15 am »
 ;D
« Last Edit: December 24, 2007, 10:23:34 pm by little_a_o »
Re: '06 Military (Discoveries)
« Reply #16 on: August 15, 2007, 10:27:41 am »
The pictures are great in this thread. If we take the time to name the pictures with a descriptive name it will make the search function work better for others. It takes an extra minute, but does help.
c1skout
« Reply #17 on: August 15, 2007, 08:31:48 pm »
It looks like those shock mounts are missing some washers or something.
justin_o_guy
« Reply #18 on: August 16, 2007, 03:15:50 pm »
That should never happen on anything. Is this an issue for others? Is it missing washers? I agree, it looks to be missing washers & almost missing the suspension.
little_a_o
'06 Military
« Reply #19 on: August 19, 2007, 12:44:26 pm »
 8)
« Last Edit: December 24, 2007, 10:24:03 pm by little_a_o »
Leonard
  • I loved this bike!!
« Reply #20 on: August 19, 2007, 04:00:31 pm »
I've received a set of washers along with a set of internal lock washers to "fix" the shock problem.  Unfortunately, it did not  close the large gap shown in the above pics.
 Is it possible that the bushing (black rubber) was installed in the wrong sequence?
If anyone has a picture of their lower shock attach points to show me Id appreciate seeing the correct installation.
Thanks.
Here are some pictures I just took of my '04 Sixty-5, sorry it's is so dirty.  If you need anything additional or these aren't large enough let me know and I can email them off forum.
==Leonard
2009 Triumph Bonneville T100
http://www.romeoriders.com
little_a_o
'06 Military
« Reply #21 on: August 19, 2007, 04:26:04 pm »
 ;D
« Last Edit: December 24, 2007, 10:24:23 pm by little_a_o »
Leonard
« Reply #22 on: August 19, 2007, 04:52:02 pm »
thanks Leonard.
Is the washer that is sitting just under the nut of larger diameter than the shock openning?  If so, that could very well be what is wrong with mine.
I didn't post new pictures of mine with the added washers because it would appear just like my earlier pictures.
little ao
  There are two washers, a flat one and a lock washer.  They are both just large enough to slip over the mounting stud.  The flat washer is not large enough so that the rubber bushing could get around it, if that is what you are asking.
  I wonder if you are just going to have to replace the bushings?
..Leonard
little_a_o
'06 Military
« Reply #23 on: August 19, 2007, 08:10:25 pm »
 ;D
« Last Edit: December 24, 2007, 10:24:45 pm by little_a_o »
c1skout
« Reply #24 on: August 19, 2007, 08:49:58 pm »
I think you should pull the shock off and reinstall the rubber bushings. The bushing should fit in the shock and have a small lip that protrudes on each side of it, there is often a steel "pipe" that  goes through the bushing  and through that "pipe" goes the mounting bolt or stud. It will be much easier to get the bushings reinstalled with the shocks off. If a lubricant is needed use something like Armor-all, petroleum by-products like grease or oil will deteriorate the rubber. The outer flat washer should be of a large enough diameter that the shock can not slide past it.
little_a_o
'06 Military
« Reply #25 on: August 20, 2007, 12:41:33 pm »
 ;D
« Last Edit: December 24, 2007, 10:25:02 pm by little_a_o »
little_a_o
'06 Military
« Reply #26 on: August 22, 2007, 05:29:00 pm »
« Last Edit: December 24, 2007, 10:25:27 pm by little_a_o »
deejay
« Reply #27 on: August 22, 2007, 07:02:24 pm »
that 2nd pic looks like you have a leaking head gasket, just like mine.
little_a_o
'06 Military
« Reply #28 on: August 22, 2007, 07:19:26 pm »
 ;D
« Last Edit: December 24, 2007, 10:25:54 pm by little_a_o »
little_a_o
'06 Military
« Reply #29 on: August 26, 2007, 04:25:33 pm »
 :D
« Last Edit: December 24, 2007, 10:26:18 pm by little_a_o »
