The Saga continues. All the other posts today were with the 117.5 main jet. So I took it out for a test ride with the 117.5. It didn't pull right in the needle part of carb operation, and when I continued onto the main jet over 3/4 throttle. It pulled ok and not great and when you rolled the throttle off, I got a little power surge. So the 117.5 main is to small.
So back I come and think. I'll just swap out the 117.5 for the 125. Just out of curosity I picked up the 125 and 120 put it next to each other to compare the holes. To my surprise the hole in the 120 was bigger than the 125! To my shock, one of the previous owners must have reamed it out.
So in with the 125. I thought simple job, nope wrong again! When you revved the engine the bike stalled again! I knew this time that it was not the needle jet not sitting correctly. So I raised the needle to the middle positon. Back together, hey presto it now doesn't stall. The air screw is 1 1/2 turns out. So I take it for a test ride and it stutters a bit under 1/4 throttle. I came back after the test ride turned up the large air screw. Sorted the cutting out. And it doesn't stutter any more, and is pulling well through the complete throttle range. I am still not happy with the idle, so I will have another go with that tomorrow.
One weird thing is the plug is still showing black soot, rich? Could a pilot jet really influence the plug chop that much? Even after a complete throttle range test/test ride?
