In the older C5, where stability was a known issue, I think the steering damper could be a useful accessory.
Less so, in on later ones with corrected geometry, or the other models with frames derived from the previous models such as G5 or B5.
The Iron Barrel models had plenty of trail, and they are rock solid all the way up to as fast as they can go, which has been up to 130 mph on certain racing Bullets. No need for a damper on them.
