I think one of the biggest problems with the clutch - at least on older models - isn't the clutch plates or assembly... it's the clutch rod that passes through the gearbox.
As you engage the clutch, that rod is forced out and takes the pressure off the clutch plates, letting them spin. Problem is, that rod has no real lubricant. It's two pieces of metal, separated by a ball bearing, spinning with the clutch plates.
Excess use of the clutch can overheat these rods and break them.
