Palampur, Himachal Pradesh
July 28, 2015, 05:02:42 am
Author Topic: Battery cable replacement  (Read 4080 times)
« on: February 02, 2014, 06:05:57 pm »
Welcome to Ducatti Scotty's battery re-wire thread.
Is it rude to start someone else's thread?  ;D
Ok, seriously... I know that he's got plans to replace his battery cables, which is also in my near future, so if all goes according to my evil plan, this is where he'll tell us about his efforts.  :P
Or, maybe not - anyway...
I've broken two negative cable end terminals, one the OEM and one the "heavier-duty" NAPA replacement.  Each time my terminal ends broke, I had to cut the crimps off and strip the wires further, shortening them each time.  So, since I plan to replace the battery with an AGM-type anyway, I'd like to replace the cables so I can lengthen and re-lead them.
First of all, I'd like to choose a battery that ideally is as close to the correct capacity required, but preferably physically just a bit smaller than the OEM one, since it's such a tight squeeze.  This may be a topic for another thread, but if anyone has any suggestions, I'm all ears…
As for the cables, I'm thinking of making them long enough so I can mount the terminals, whatever format they take, and lead the cables down along the sides of the battery.  I'd like to firmly anchor them to the battery, and have the cables loop away from the battery gradually and let the flexibility of the stranded copper cables absorb the vibrations that broke my previous terminal ends.
Things to which I'm giving consideration:
  • If the cables are going to be longer than OEM, should they be a heavier gauge?
  • Over time, will vibration cause the copper cables to fatigue and fail just as the cable ends did?  If so, maybe I should just consider the cable ends to be a weak link and plan on periodic replacement (but not once a year, surely?).
  • Does it make sense to consider adding bus bars for connecting the battery, charger connection and other accessory connections, rather than trying to cram all those connections directly onto the battery terminals under that tight cover?
More anon...
Re: Battery cable replacement
« Reply #1 on: February 02, 2014, 06:19:19 pm »
I use a 14 ga ground with eyelet terminals. Don't use a bus bar and have a charger connector connected. no problems. I also chucked the battery box and built a custom battery box to go in the LH toolbox.
« Last Edit: February 02, 2014, 06:41:39 pm by Blltrdr »
2009 HD FLHTPI Police 103
« Reply #2 on: February 02, 2014, 06:37:55 pm »
Wrap the longer wires around a phillips and make a coil. Then run it to the battery. That'll keep them from breaking.   ERC.
« Reply #3 on: February 09, 2014, 10:49:29 pm »
Not many pics but I'll tell you all the details:
First things first: remove the battery so nothing arcs and you don't get hurt.  If you can remove the seat and tank it makes everything really easy, though probably isn't necessary.  Save any rubber boots that are on battery lines and reuse them on your new ones.
And some advice.  There are three battery lines.  Remove one line at a time, make the new one, and replace it.  Test to make sure the bike still starts.  Move on to the next one.  If you remove them all at once you might, say, crosswire the positive and negetive terminals at the starter, fry your solenoid and brand new $100 battery.  Ask me how I know ;)
The stock RE wires are crap.  This is not specific to the RE, almost all stock moto battery lines are crap.  The RE positive lines are 8 gauge (barely adequate really) and they're wrapped in two layers of stiff insulation which makes them look bigger than they are and also makes them a real bear to bend.  The negative lead is just a 10 gauge wire.  That's really anemic.
Materials:
-10' black 6ga. ultra-flexible battery wire, part #6948K91.  It cost me about $25 delivered and was plenty.  I could probably make another set from what's left.  This is a nice burly wire with very fine conductors and a rubbery flexible insulator.  It should be really easy to bend wherever you want/need to and will carry way more current than stock.
-Napa Auto battery terminals, part #784572.  These are 6ga. and have a 1/4" hole.  $4 at any Napa.  I've used these for a long time now.  The only time they've failed is from bending back and forth too many times from the battery going in and out too many times.
-Heat shrink tubing.  I got some clear stuff at my local Ace Hardware that has a heat activated adhesive on the inside, so it stays put once you shrink it down. $5 for 6", and worth it!
-Electrical solder and a torch.
There are three cables to make.
-Positive battery to starter solenoid.
-Negatve battery to starter motor ground.
-Solenoid to starter positive terminal.
Some REs have a solenoid with the wires permanently attached, covered under some potting compound.  If you have one of these you'll need to replace it.  Get something like this:
http://www.ebay.com/itm/like/230691411498?lpid=82
Get one that's for a 500cc or larger bike.  This is what I got as a replacement from CMW when my original died.  Throw away the green plastic piece, you won't need it.
The easiest cable is the solenoid to starter positive terminal.  This just has two terminal ends with heat shrink.  Remove it from the bike.  Measure and cut a new line the same length.  Remove the rubber boot that covers the starter terminal and slide it to the middle of the new line.  Now put the ends on.
Use a razor blade and cut off about 3/8" of the insulation, just enough so that when the wire is inserted in the cable end it comes up just flush with the collar but doesn't stick out.  Crip it closed.  I used a big pair of Vice Grips for this.  Repeat for the other end.
I soldered the ends but just a little bit.  Some people will tell you not to do this.  If the lin gets hot, the solder can melt out and drip on things.  You don't want to use tons of solder.  I put just enough solder on the cut end to anchor it to the termninal.  If you put on so much that it flows out the other end it will make the line rigid there, it won't flex, and it will break off.  Just enouch to fill the top, get it nice and hot with a torch so it flows.  Then I tap it off to get rid of all excess.  Then heat again to make it flow and make sure it's not a cold solder joint.  Repeat for the other end and set aside.  Let it cool completely before you put on the heat shrink tubing.
If you can find the adhesive heat shrink, use it.  It's pricey, about $5 for 6" but worth every penny.  It's really thick and heavy and once heated you can see liquid adhesive flow.  It stays put and the thickness helps distribute any bening at the terminal across a wider area so your line is less likely to break off.  I cut it long enough to cover the entire metal collar and about 1/2" to 3/4" past that down the line.  Hold in place, heat and shrink.  Let cool.  Now slide the boot back to the end.  A little Windex makes this easy.
The other two lines are similar but each also incorporates a small tap line off the main line to feed the electrical system.  There is a quick disconnect for these feeds.  SAVE IT AND REUSE IT!!!!  Do not replace it with a bullet connector.  Bullet connectors suck.  They corrode and get loose very easily.  These quick disconnects are much better, more secure, and much less likely to corrode or fall out and leave you stranded.
Cut the small line as close to the old main cable as possible.  Strip about 1/2" - 3/4" of the insulation and wrap it around the stripped section of the new main line.  Crimp and solder the end as before.  Tug the small line and make sure it's secure.  With the heat shrink, make sure it covers at least 1/2" past the metal collar.  This is important for these small tap lines since you don't want to be yanking at the line near the terminal.  The small line will fatigue and break, leaving the bike dead.  The heat shrink distributes the load.
For the negative line I made one the same length as the original.  For the positive I made one longer because I'm routing it a different way.  On my C5 it was running right along the backbone of the frame.  That has some problems.  It gives you almost no room to maneuver and get it attached to the battery, or to push it back in place as you insert the battery.  I routed it lower, behind the battery bracket.  The line is a little smaller than the original (since it doesn't have two crappy layers of insulation) so this was easy.  I figure I'll route it up from there to the positive terminal.  This gives me an easier angle of approach and more slacke to slide the battery in and out but I'll have to be careful I don't leave too much slack.  If there's too much slack it will swing around and either chafe through the insulation or break off at the terminal.
If you're wiring routes don't match mine, done't worry.  I'm pretty sure not two REs you run across will have the exact same wire routing.  Again, this is not unique to RE, most motos are like this.  I'll try to get some pics and add them to the post.
On batteries, I got the MotoBatt AGM for about $100 and was really happy with it.  It has threaded holes that you're supposed to bolt these little terminals to, then bolt the wires to the terminals.  I tossed the terminals and just bolted the lines to the threaded holes in the battery.  Since they are recessed it was really easy to bolt up and get the battery in place.  As mentioned above, I fried that battery through my own stupidity.  I wasn't really up for another $100 so I looked around and found Chrome Battery for $42 shipped.  It's an AGM but with more common terminals.  It's the 14L-A2, exact same size as the original.  It will probably be a hassle to get in but the terminals are a bit different and that should be easier.
For attaching more leads for chargers, etc.  The positive line has always been the the biggest pain for me because of where it is and how little room there is to get anything in there.  I plan to bolt my charger line to the solenoid instead.  It's the same connection, but I don't have to wrestle with it every time I put the battery in and out.  Unfortunately the negative lead doesn't go anywhere so convenient.  It's got a bit more room behind the battery, but I may add a 6" long 12 ga. line to the terminal and attach to that.  That should be a bit more convenient since I don't have to deal with more than one ring terminal going to the post.
« Last Edit: February 10, 2014, 01:17:25 am by Ducati Scotty »
« Reply #4 on: February 10, 2014, 01:11:25 am »
Cables.  McMaster Carr on the left, stock center and right.
New positive battery cable end.  There's a little red tape under the heat shrink, just a touch of solder to hold it together.
Positive battery cable with side tap at the solenoid.
Negative cable with side tap.  Note how the heat shrink holds the smaller line so it doesn't break off.
The Chrome Battery L14-A2 AGM in place on the C5.  The printed spec said it was the exact same size as stock but in reality it's a smidge shorter and narrower.  Some bending of the battery case, tighter straps, and maybe a paint stirring stick wedged in there should keep it secure.  It was easier to get in, but that's probably partly due to the tank and seat being removed.
« Reply #5 on: February 10, 2014, 05:45:52 am »
Wow, I should start threads for other people more often!
Thank you Scott; that was above and beyond...
I just ordered a similar battery to yours - I haven't received it yet, but it appears in the web photos to have the ability to attach the terminals at what I'm going to call the front (side with the label) as well as at the top.  I wonder if side attachment would be easier on the terminal ends?  But maybe there isn't room behind there, between the battery and the frame; I can't remember.
Because I've had to cut off and replace the negative terminal crimps multiple times, the negative "tap line" (ECU feed) is getting very short, so I might need to replace it as well...
« Reply #6 on: February 10, 2014, 06:37:50 am »
I've looked for "quick disconnect" fittings, and only found those "spade" type ones:
If I want to reuse my current locking "tap line" connector, is it easy to remove and "uncrimp" the wire from the fitting, and substitute a new wire?  Or should I look at buying a new fitting?  What are they called, and where should I look for them?
« Reply #7 on: February 10, 2014, 06:38:59 am »
Mattz - Search bullet terminals or spade terminal to find "quick connectors".
Scotty - Well done!  Nice work.
Scottie J
« Reply #8 on: February 10, 2014, 06:55:36 am »
Scottie-
You'd think that bullet terminals would be just the thing!  Sorry...
Searches for bullet and spade terminals return those items, which isn't what I want - I've got piles of those types.  I'm looking for the locking type that's currently used...
« Reply #9 on: February 10, 2014, 07:04:11 am »
Scottie-
Do you have a pic of an old one?  I guess I'm confused as to what style you're looking for.  There are literally hundreds.
« Reply #10 on: February 10, 2014, 08:27:26 am »
Sorry I don't have a better pic, but here is a shot from the RE manual.  It's a square profile, locking connector...
« Reply #11 on: February 10, 2014, 09:26:53 am »
Mattsz, this battery allows connection to both top and front.  Top just seems easier to me.  Go with what works for you.
My negative side tap was really short too.  I soldered 6" of 14ga. to it.  Oregon Motorcycle Parts makes lots of click connectors, but they only go as small as two conductors.  If you need to replace it a spade is preferable to a bullet.
« Reply #12 on: February 10, 2014, 01:19:58 pm »
Oh, and I'm a C5 and the picture in your post looks like a G5.  Obviously different.
« Reply #13 on: February 10, 2014, 06:35:21 pm »
Scott - I'll look at it when I do the rewire and installation.  My B5 does have a different battery cover than your C5, so an obvious different lead may make itself apparent.
As you say, in a pinch I can simply lengthen the end of the wire I've been shortening due to cable terminal breakage.  Any soldering I do to that wire can be isolated from vibration, and will not be subject to solder-melting heating from high current... and I can just keep using the same connector.
BTW, that pic was a "stock" photo grab, simply to show Scottie the connector I was describing - I added the pink arrow...
Still interested in potential replacement, since another one broke its locking tab and I had to wire it together.  Can't remember which one right now, though!  :(
Interesting, my wiring diagram doesn't show any single-wire connectors, in the EFI ground circuit or anywhere else.  But, it also shows two spark plugs, so who's counting?  ;)
« Reply #14 on: February 12, 2014, 06:50:26 pm »
The plot thickens...
I, of course, have the permanent "potted" solenoid.  So now I have to think about replacing it.
I'm not sure what to do.  My wiring diagram shows four wires - One from the battery, one to the starter, and two (blue/white and black) from the starter switch - makes sense...
My actual solenoid has five wires - the two heavy cables from the battery and to the starter, and three thin wires: solid blue, white and red...
I don't know what the extra wire does, so I'm not sure about how to replace the solenoid with a different model.  Also, the OEM solenoid bolts securely under the seat with two bolts; any advice about attaching a replacement solenoid?
BTW, remember I mentioned a connector with a broken lock?  There it is, the two-wire one with the blue and white wires... I've got a wire-tie wrapped around the connector to keep it together...
