Home
Search
Calendar
Login
Register
Login
Register
Link 1
Link 2
Link 3
Link 4
Link 5
Unofficial Royal Enfield Community Forum
Royal Enfield Motorcycles
Bullet Iron Barrel
petcock threads?
Login
Register
HITCHCOCKS SUPER BLACK FRIDAY EVENT
22nd NOVEMBER UNTIL MIDNIGHT 26th NOVEMBER UK TIME
SHOP NOW
10% OFF
EVERYTHING
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: petcock threads? (Read 5882 times)
solg
Grease Monkey
/Users/solgualtieri/Desktop/165532_489778052839_61
petcock threads?
on:
February 02, 2014, 11:10:03 pm
does anyone have information? I am trying to determine what threads are on a 2008 iron barrel Karcoma brand petcock. I thought they were BSPP but,They are different than the BSPP brass adapter I have.(see photo)
Last Edit: February 02, 2014, 11:20:28 pm by solg
Logged
The computer can't tell you the emotional story. It can give you the exact mathematical design, but what's missing is the eyebrows. FZ
Grand Gearhead
World leaders in performance/racing Bullets
Re: petcock threads?
Reply #1 on:
February 03, 2014, 01:08:40 am
I don't know. It seems the threads are always changing on RE things. It might be metric on late models. Or not.
I usually just try different things in the hole until I find what fits. Then you know what it is.
Logged
solg
Grease Monkey
Reply #2 on:
February 03, 2014, 01:35:18 am
i haven't found anything that fits that thread. Im wondering, could cut that stub off and drill & tap it for 1/4" NPT ?
Logged
Grand Gearhead
Reply #3 on:
February 03, 2014, 01:41:46 am
I think you could just drill it and tap it.
Logged
Ballroom dancer
Scooter
Reply #4 on:
February 03, 2014, 06:04:42 am
Slow down for a moment. Why are you replacing the petcock? I have repaired three of these and they fail because of a weakness in the design. If when removing or installing the petcock it is turned even a little bit the nylon reserve tube shears off. I repair them by installing a piece of brass tube from the hobby shop in place of the nylon screen, seal, reserve part. The tube is just a touch small so I expand it by putting an arbor (number size drill bit shank) inside and very lightly tapping it while rolling it on a steel block. When it's almost a push fit I locktite the tube in place. Must use an inline filter after the modification.
I don't have the answer to what size the thread is but the nut which connects the petcock to the the tank spigot is both left and right hand threads. The pitch of both of these appears to be 1 mm. Oh, one more thing. I use a thin slice of 1/4" urethane tube for a gasket although if you have an O ring the right size that should work. I also show a Briggs and Stratton petcock from a lawnmower shop. I've used these on ultralight airplanes and they work fine if you decide to go that route. The Briggs and Stratton petcock is 1/8" pipe thread. If you want I could repair your petcock for you but you must have the nut.
Logged
Grand Gearhead
Reply #5 on:
February 03, 2014, 12:15:14 pm
I think that his problem is insufficient fuel flow at higher rpms on his
Fireball, so he needed the fuel tap to flow more fuel than the previous one he had.
Logged
solg
Grease Monkey
Reply #6 on:
February 03, 2014, 03:14:22 pm
Yes Mr Ballroom. Tom is correct. The petcock I have is actually in good shape with no leaks. This was adequate for the bike in stock form. My concern is for the performance demands of my bike in its Fireball form. Although I have not opened er up yet as it is still a pretty fresh build, I can see the stock petcock having a hard time keeping up with things. After all the Pingel fuel taps "pass more gas"
Last Edit: February 03, 2014, 03:17:19 pm by solg
Logged
Ballroom dancer
Scooter
Reply #7 on:
February 03, 2014, 05:07:17 pm
Thanks guys. Now I know what I have to plan for someday when I modify the engines on my 06 and 08 iron barrels.
Logged
ERC
Grand Gearhead
Reply #8 on:
February 03, 2014, 07:36:40 pm
The threads on that petcock should be 1/4x19 BSPP. I just measured a couple I have and they come out to that size. ERC
Logged
solg
Grease Monkey
Reply #9 on:
February 03, 2014, 11:07:48 pm
Thats what I am told but, as you can see by the above photo the BSPP fitting is a bit larger in dia(.51") and coarser in thread (19 TPI). The threaded stem sticking out the bottom of the tank is .45"in dia. and the threads are metric (1.0) that stem is more like 12mm X 1.0
Logged
ERC
Grand Gearhead
Reply #10 on:
February 04, 2014, 07:57:13 pm
I looked on Hitchcocks site and your shut off looks like what they describe as a Karkoma shut off and it says you need an adaptor that they sell. ERC
Logged
solg
Grease Monkey
Reply #11 on:
February 05, 2014, 03:02:33 pm
Yea, I called Hitchkocks this morning. They say that adapter won't work in my application
Logged
ERC
Grand Gearhead
Reply #12 on:
February 05, 2014, 03:21:20 pm
Not cool you'll have to do some thread cutting. ERC
Logged
Grand Gearhead
Reply #13 on:
February 05, 2014, 04:50:51 pm
I just talked to Chumma on the phone.
He says he will email you about some method that he worked out to handle this petcock issue.
Logged
solg
Grease Monkey
Reply #14 on:
February 06, 2014, 12:07:41 am
Email received. Thanks Tom. Ive already cut off the tank stem though. Im in the process of boring it now. ill find out shortly how taping a pipe thread into it goes.
Logged
devon john
Scooter
Reply #15 on:
February 15, 2014, 05:15:15 pm
just done that , cut the male tube off drilled out and taped to 1/4 "BSP .
theres plenty of meat there and now loads of choice of taps.
john
Logged
harley hydra glide FL (1950)
harley FLH 80
535 Royal Enfield bullet
solg
Grease Monkey
Reply #16 on:
February 15, 2014, 07:26:19 pm
after cutting off the pipe weenie sticking out the bottom of the tank. i taped it for 1/4' pipe thread.I made a bad choice in Ebay sellers or I would have included a pic of the petcock mounted to the tank. This photo will follow.
Logged
solg
Grease Monkey
Reply #17 on:
February 21, 2014, 02:50:44 pm
Well, the project is complete. Rod, you are right the Pingel is a bit pricey but its well made, completely rebuildable, and the action is incredibly smooth! Not to mention it looks awesome.I should have no issues with fuel flow with this thing.
Logged
aleman
Bulleteer
Reply #18 on:
February 22, 2014, 07:21:25 pm
Hey, hey! I'm glad you got that worked our Solg. That looks great, and a little more compact than my set-up. Yeah, it's spendy, but just a superior way to go. You'll never fuss with it again. Nice job.
Logged
FB 002
solg
Grease Monkey
Reply #19 on:
February 22, 2014, 09:00:07 pm
Thanks. I had a coupling on there at first but the outlet tube aligned better without it. Its subtle details like this that I enjoy.
Logged
Print
Pages:
1
2
All
Go Up
« previous
next »
Bullet Iron Barrel
petcock threads?
Login
Welcome,
Guest
. Please
login
or
register
Have you missed your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length.
