Color Concepts
May 29, 2016, 04:19:51 pm
Author Topic: You're Not Going To Believe This!!!!!  (Read 1449 times)
« on: January 20, 2014, 08:01:26 pm »
JVS
  • I love chicken
Re: You're Not Going To Believe This!!!!!
« Reply #1 on: January 20, 2014, 08:25:16 pm »
Damn!!!  :o
I'm really glad you're okay! Scary stuff.
ERC
« Reply #2 on: January 20, 2014, 09:03:19 pm »
Did this just happen? On some models the breather exits into the primary so the pressure has to be relieved from the primary by a fitting or a hole drilled into the filler plug.   ERC
azcatfan
  • 2002 Bullet ES
« Reply #3 on: January 20, 2014, 10:24:53 pm »
Wow, dude!  Nice job keeping it together at speed.
As for the primary, I always thought the hole where the alternator wires come through would be the place to give due to pressure.
I'm glad you're safe...
« Reply #4 on: January 21, 2014, 06:34:22 am »
Probably it was just the heat expanding the air inside, causing it to pop. If it was dry, the the heat could build up pretty quickly with no venting.
However, I have to admit that I have never seen or heard of that happening before.
AgentX
« Reply #5 on: January 21, 2014, 06:40:54 am »
Crazy!!!
One question...you say your alternator cooked itself because it was run dry?  The rotor and stator aren't in contact, so I didn't think it'd be a problem.  Always thought that the primary chain and clutch plates (on the stock wet clutch, anyhow) were the reasons for the lubrication.
Ask as I was planning on running a dry clutch from Newby.
« Last Edit: January 21, 2014, 04:34:41 pm by AgentX »
« Reply #6 on: January 21, 2014, 07:04:51 am »
Crazy!!!
One question...you say your alternator cooked itself because it was run dry?  The rotor and stator are in contact, so I didn't think it'd be a problem.  Always thought that the primary chain and clutch plates (on the stock wet clutch, anyhow) were the reasons for the lubrication.
You can run a dry clutch and dry primary, but you have to provide plenty of cooling vents when you do that. It can't be sealed up. It needs some air going over it.
« Reply #7 on: January 21, 2014, 07:29:26 am »
I've been pondering this event ALLLLLLLLL night long.  The only conclusion I could come to, is that somehow, the primary cover was never completely seated (it's been a cunt ever since it broke and I had to have it welded up) and all the ATF had slowly, or quickly, who effing knows, drained out of the primary which obviously had been causing some serious friction.  I had noticed a small bit of smoke coming out of the hole where the alternator wires come out.  I pulled over and stuffed my face an inch from my exhaust to get a whiff, wasn't electrical, metal or oil.  I had smelled it before but couldn't pin point it and associated it with heat and the cold air and kept riding.  I guess it was the smell of burning epoxy, and I got to smell it for over an hour waiting for the tow truck to show up.   :o    When you watch the video, the sound is extremely deadened due to a sensitive mic and loud exhaust.  You really can't hear the exhaust at all in the video, yet my primary popped loud enough to be heard over the exhaust.  So, is it possible that with the little amount of oil and the mass amount of heat that the ATF vaporized and ignited and actually BLEW my center nut off?   ???  I mean, I have a small bruise on my ankle bone this morning, it didn't just fall off.  In fact, I'm pretty sure the guy in the utility truck I was passing thought I completely blew up my motor.  It sounded like a gun shot when it went.
« Last Edit: January 21, 2014, 07:32:32 am by Scottie J »
heloego
« Reply #8 on: January 21, 2014, 08:30:04 am »
Scary video, Scottie. For you and the guy in the truck!
Glad you're OK.
« Reply #9 on: January 21, 2014, 08:43:50 am »
...ignited and actually BLEW my center nut off?   ???
Well, at least it was only your center nut.
You still have your left nut and right nut left!
 ;D
cyrusb
  • Kept man
« Reply #10 on: January 21, 2014, 08:47:04 am »
Did it strip the center holding bolt threads?
azcatfan
  • 2002 Bullet ES
« Reply #11 on: January 21, 2014, 09:02:09 am »
 ;D
I was waiting for an equally minded person to crack wise on him blowing a nut....   ;D
« Reply #12 on: January 21, 2014, 09:30:20 am »
 ;D
Right you are!   LOL  ;D
I just might say screw it and order a belt drive.  I'm sick of my clutch slipping anyways.
The center stud appears to still have it's threads.
« Reply #13 on: January 21, 2014, 12:35:35 pm »
Some Enfields came with the crankcase breathers blowing into the crankcase and had breathers on the back of the primary cases to take care of the pressure. Over time some got replaced with the nonvented ones and blowing them off was not unusual!
As for oil in the crankcase, the chain still needs it!  I guess the oil could be used to cool the alternator, too.
Don't know why you'd lose control of the bike because the primary blew off, especially if the oil was already gone and there was nothing to blow all over the real wheel, which can make things a bit sporty!
Anyway, interesting clip!
AgentX
« Reply #14 on: January 21, 2014, 04:37:04 pm »
Oooh.  Any excuse for speedholes!!!
