I replaced my sprag assembly. Do some searching, I posted pics of the sprag clutch.
I had some difficulty getting mine apart because the snap ring that holds the clutch in place didn't have holes for snap ring pliers. No matter what I did (including destroying the original already damaged sprag) I could not get the ring out.
I ended up sending mine to Vince in Washington for dissasembly and to have him modify the shaft that the assembly rides on for better lubrication. It turned out that the surface that the sprag rides on had been scored by the bad sprag and I had to replace the whole assembly and not just the clutch (on the plus side, I have a spare sprag now if the new one goes).
The new assembly came with a proper snap ring and I was able to put it all back together and into the primary case in about 30 minutes.
Once back together, and with a new battery, it works like brand new. I don't do anything special, just turn the key and hit the button and it fires up immediately with no extra noises or drama.
