In case anyone is wondering why we would want to change the shape of the combustion chamber, have a look at the shape of this winning 1500hp Pro-Stock chamber.
Our chamber is not shiny because we have the Thermal Barrier coating applied on it.
The shape is very similar, and the variations are due to the fact that our head has a different port bias angle, so the flow pattern is different.
The aim is to burn the mixture as rapidly and completely as possible, so that the most power can be extracted from the fuel. It's great to get a lot of fuel/air in there, but that's only half the battle. Then we have to completely and efficiently burn it to make power. That's where the combustion chamber work pays off. You can't measure this on anything like a flow bench. This just comes from experience of knowing what works.
