No worries, Roverman! Your input is always welcome, plus this is a community forum
See, I was following the manual. Front pressure is recommended to be 18-20psi and the rear at 28-30psi. I had no problems with these pressures and I was okay with it. Handling was acceptable for me also. Mileage was always good. I had been averaging 73.62mpg and on my last fuel-up I got 81.45mpg. This is with the stock tyre pressures.
Regarding the 28psi on the front K70. This is not a good idea because when I got the tyres back on, I checked the pressure and both were at 30psi. So I brought down the rear to 28 and the front to 27.6 or something. Now, when I went for a ride, I noticed that the front was 'bouncing' a bit more than it should...even on the flattest of roads. It was pretty obvious for me that it was the higher pressure at the front. So I reduced the front K70 pressure to around 24, and it has been running very well!
Craig, again, I'll bring my previous post in the 'k70' topic -
Sure the 3.25 is the desired size at the front, but I am willing to experiment. Call the 3.5 a rock crusher, but I am sure the little change in handling is not going to bother me a lot. I am not going at light speed here like an R1, CBR1000RR, Panigale or S1000RR, nor I will be doing the Isle of Man TT on an Enfield Bullet.
I will be riding for pleasure...whether it be city/town or the twisties, and I am prepared to put an extra effort in entering a corner with a 3.5 up front. It can't be that bad and I am sure I can drag the left footpeg + right brake arm all day long with the 3.5 up front also.
Again, this is my personal choice and will surely report on the ride when I swap to the K70s.
Of course you cannot argue with the facts, but I just made a little compromise in favour of looks as compared to performance. Trust me, the performance isn't really that bad, lol.
