Home
Search
Calendar
Login
Register
Login
Register
Link 1
Link 2
Link 3
Link 4
Link 5
Unofficial Royal Enfield Community Forum
Royal Enfield Motorcycles
Bullet Iron Barrel
carb intake gasket
Login
Register
HITCHCOCKS SUPER BLACK FRIDAY EVENT
22nd NOVEMBER UNTIL MIDNIGHT 26th NOVEMBER UK TIME
SHOP NOW
10% OFF
EVERYTHING
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: carb intake gasket (Read 1285 times)
guss,guss
Grease Monkey
picture is not actual bulleteer
carb intake gasket
on:
January 14, 2014, 10:02:38 pm
hello gearheads.
i bought this last summer. i don't know if the first owner added extra gaskets or is this the way they come? the person i got it from was the second owner. he said when he got it , it had been sitting out for ten years or so. i don't think it leaks. i sprayed a mist of wd 40 around and no change in the rpm. it just looks bad.
so should i go ahead and replace them, and is it normal to need three layers of gasket?
thanks.
Logged
Kill em all, let God sort em out.
Have a nice day.
Grand Gearhead
World leaders in performance/racing Bullets
Re: carb intake gasket
Reply #1 on:
January 14, 2014, 10:25:15 pm
If there is no leak there, then it's okay. They may have been trying to make a heat resistant spacer.
Logged
edthetermite
Grease Monkey
The Emperor has no skin.
Reply #2 on:
January 18, 2014, 02:39:57 am
One thing to watch out for is the angle of entry into the carb top by the throttle cable. The extra spacers could cause it to be misaligned to the point of impeding smooth cable movement. My tank's underbelly is constantly trying to relocate the throttle cable to something less than ideal.
Logged
Ed - Long Live the Iron Barrel !!!!
2008 Military RE "535" 2006 Ural Gear Up
guss,guss
Grease Monkey
Reply #3 on:
January 19, 2014, 12:00:53 am
thanks for the advice.
i guess if its not broke don't fix it. it does look bad. so when it does come time to replace it are multiple layers a good thing? i don't see any heat spacers for sale unless its got an amal. mine is not.
Logged
Have a nice day.
Grand Gearhead
Reply #4 on:
January 19, 2014, 12:41:11 pm
If it's just the ugly hose clamps that are bothering you, you can remove them, trim them down with a pair of dykes, and paint 'em trim black. It will make it a lot cleaner and not nearly as noticeable.
Logged
Gotten my hands dirty on bikes more than once -
Global Moderator
Grand Gearhead
Cozy Sidecar distributor/former Royal Enfield dist
Reply #5 on:
January 19, 2014, 11:35:33 pm
No need for three gaskets
Logged
www.cyclesidecar.com
Print
Pages: [
1
Go Up
« previous
next »
Bullet Iron Barrel
carb intake gasket
Login
Welcome,
Guest
. Please
login
or
register
Have you missed your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length.
