Hi all,
I’ve just replaced my starter solenoid with a ford one. Just letting you know what I did.
NOTE: This mod removes the neutral and clutch safety switches, so after this mod, the starter button will activate the starter motor no matter what! This is due to the earthed mounting bracket on the ford solenoid.
You will need -
Ford Starter solenoid
Two 10mm-8mm heavy duty ring crimp connectors
Two 5mm light duty ring crimp connectors
One 8mm light duty ring crimp connector.
One 1000V 3A power diode
Steps
1. Remove the battery and seat.
2. Undo the old solenoid by undoing the two bolts, disconnect the positive connector and the starter wire connector.
3. At the solenoid, cut all wires as close to the solenoid as possible.
4. Strip the positive battery (thick red) and smaller power (red) wire and crimp them together with the heavy duty crimp connector.
5. Strip the brown starter motor wire and crimp with heavy duty connector.
6. Strip only the starter (blue) wire and crimp with the 5mm ring connector. ( tape up the other wire as it is unused!!! )
7. Make the shunt diode circuit by crimping the “silver banded” end of the diode to the 5mm ring connector. Solder about 5cm of wire to the other end. Strip the end of the wire and crimp the 8mm light duty ring connector.
!!!!!!! WARNING - FAILURE TO GET THE DIODE POLARITY RIGHT WILL RESULT IN BURNT WIRING!!!!
8. Connect both the 5mm ring connectors of the starter wire and the diode circuit to the right post of the solenoid.
9. Connect the battery cable connector onto the end closest to the battery (palarity doesn’t matter, but convenience does)
10. Connect the starter cable connector to the other end.
11. Mount the new solenoid where the old one used to be, don't forget to connect the other end of the diode circuit to one of the mounting bolts to earth it!
12. Double check all wiring and reconnect the battery.
13. Turn bike on and crank away!!!
