Here is a tidbit from the Danish importer Jan O. Nielsen off the E-Group (Yahoo group) of yesteryear,
"BE GOOD TO YOUR GOSA ... and your GOSA will be good to you!
Take off the gearbox cover. Inside in the upper right hand corner you'll find a
screw with a lock nut on it. This screw is the GEAR OPERATOR SELECTOR ASSY (part
no.111094), the "GOSA".
Take out the GOSA. The pointed end of the GOSA is held by a spring, and this is
the arrangement that together with the GEAR OPERATOR INSIDE (part no. 111083)
keeps the gear wheels in position.
The problem with the GOSA - according to our mechanics - is that the spring
inside it too often too hard and that the pointed end is too rough. You can
polish the end of the GOSA so that it becomes very smooth, but remember that it
has to remain pointed.
With a little screwdriver you can detach the pointed end of the GOSA and remove
the spring. Replace the spring with a spring only half as hard and attach the
pointed end again.
(You can also - like one of our mechanic do - simply drill the inside of the
GOSA deeper, thereby relieving the tension of the spring. But there is no going
back from this)
The pointed end of the GOSA should now be easily moved up and down.
Screw the GOSA back in again all the way and then turn it back again two or
three clicks.
The slot in the GOSA should be horizontal when in place and then you can
retighten the lock nut while holding the screw horizontal.
Now you gear should be easier to operate, but remember: no guarantees!
Please let me know if I'm unclear. My technical english could be better."
The factory started using weaker springs shortly after this came out but still can be improved on with honing and polishing,
CJ
