A better protected system..... Less smoke !
My guess would be... without seeing it.... Is 1 main 15 amp fuse and 1 spare 15 amp fuse. 3 active 10 amp fuses for the circuits, and 1 spare 10 amp fuse.
That looks like the ECU. You want the RR out in the breeze, it gets hot. Scott
Ah, yes it is! And a great spot for it. The alternator, battery, and RR all near each other makes for a simple and short charging circuit. If I were to rewire mine that's where I'd put it. Scott
It needs a little airflow. Ducati made a batch of Monsters with them under the seat. They burned up pretty often. But just out in the open is usually good enough. Don't worry about it being in the "hot air" behind the cylinders. Scott
