Chrome c5
May 06, 2016, 06:11:56 am
Author Topic: Disc brake lever compatibility?  (Read 435 times)
AgentX
« on: December 26, 2013, 02:29:09 pm »
Hi all--
Anyone know if the lever blade on the stock Enfield disc brake master cyl/lever assembly is interchangeable with any other bike?
Thanks!
AgentX
Re: Disc brake lever compatibility?
« Reply #1 on: December 27, 2013, 03:47:01 pm »
Well, went to the local shop today.  A lever on the wall looked like it'd fit if it was milled to be a bit thinner.  (Even had the brake light switch actuating paddle part...)  Parts guy told me it was spec'd for an "old gold wing."
Reason I asked was I was thinking of using a modern offroad clutch lever on my bike with the "hot start" lever (such as an ASV f1 or f3) to actuate the decompressor.  Figured I'd want to go with a matching brake lever on the other side if I went this route.
Left the store with an MSR lever which looks similar enough to the stock lever blade shape that I think it'll work, but am also thinking of sticking with the more vintage-style separate decomp lever blade/perch.
« Last Edit: January 01, 2014, 05:54:42 pm by AgentX »
« Reply #2 on: December 27, 2013, 04:27:38 pm »
I was actually thinking of putting some MSR levers/perches on the Blackhawk.  Mine are all beat up and I just really like the way MSR levers are designed and pull.  Plus they're affordable and readily available.
