G'day lads, I'm just in the process of cleaning and de-Incidentally ,by the time I scraped all that carbon off my piston it came to be about two teaspoons worth - heaped. Like I used to put in my coffee . The piston dish was solid build up. Seems like a lot - that injection of water is lookin like the future....every 5000 k or so I'd reckon
carbing bits of engine while I wait for my magneto puller and valve spring compressor to arrive...120 bucks ouch ... And in my ignorance I'm wondering can I/ should I re- use the piston rings ? They seem to be in good nick.
Do you think you need new rings Dave !?..... Ah.. YEAH !
At least. And depending on how deep the damage is on the cylinder wall and piston. You may need an overbore and a piston and ring set. I would take in to a local Automotive machine shop and have it looked at. And if you need it, they can fit the new piston for you. Don't go cheap, when you have it all apart now.... and like Scottie said ,your doing all this work.
You don't have to wait for the spring compressor... sears sells the perfect U shaped spring compressor for these bikes BTW.... if you want to get busy cleaning out and checking the head. Just get a deep socket, about the same size as the valve spring cap. Place it on top, and give the socket a sharp wrap with a mallet. The keepers will pop right out, and you can take the valve, spring, cap, washer apart. Don't forget valve seals and to check your valve guides.
You could have forgone the rotor puller. An aluminum wedge works just as well. Just place it behind the rotor, and tap it... move it around.... tap it.... move it around... tap it. And the rotor pops right off.
And i'm thinking, a lot of that crud you cleaned off of the piston crown with the carbon, was oil from your piston slapping around......
Also check the valve train while your at it. the lifters, the lifter bores, the push rods are straight, measure your valve springs and etc. Basically, go through the service manual and check all your specs.
