my bullet
May 01, 2016, 08:42:06 am
Author Topic: Bad engine noise from C5  (Read 3930 times)
gashousegorilla
Re: Bad engine noise from C5
« Reply #45 on: December 03, 2013, 02:48:54 pm »
  Singh, you could try a compression test.  Do it using the starter, with a fully charged battery....hopefully the auto decomp won't skew the readings this way.  Disconnect the fuel pump and throttle wide open when you do it..... see what you get.
 And when I say disconnect the fuel pump..... I mean electrically... Sorry, unplug it.... So you're not spraying fuel in as you test.
