Hello all,
I am enjoying my B5 a lot. But, it has a sweet spot of 50MPH. Above 55mph, the vibration is just too much. Is this normal? I expected to cruise at 60mph smoothly. My bike has 2K miles on it. Thanks.
I agree with Royalista. With a 500 single, you should be expecting 'some' vibrations, yeah? But if the vibrations are too much, i.e. you think the bike is going to explode or something, then you really need to go over the bolts etc. It is hard to judge because we are not sure how much vibration you're getting.
Plus, try to stay around the 55-60mph mark. That is where these bikes run best. Anything over that is just overkill for a stock Bullet (unless you're trying to overtake
), even though it can withstand higher speeds.
