Question for TM 32 'practitioners'
How much do the needle jet and needle overlap between 1/4 and 1/2?
I've seen the VM curves and get that the carb is mostly on the jet at 1/4 and then transitions onto the needle (so to speak) more towards 1/2. Are the VM and TM about the same?
Why I ask.... So I thought I was too lean between 1/4-1/2, so I move the clip one richer. Still didn't like the performance, so I shimmed it. Result? Sotty sotty plug. Black. Also noticed lots of hesitation and began to identify this as a rich surge. Ok, I read the bike wrong. Put clip on the 2nd leanest with a shim, and no rich surging... So, basically I'm nearly back where I started, except .5 clip leaner. P6, needle shimmed at 2nd from the top, 190 mains.
So, if I change to a p4 needle jet, how much impact does that have at 1/8-1/4-1/2 if I leave the clip where it is now?
Thank you for any and all insight.
