Author Topic: s cams  (Read 48932 times)
armando_chavez
Reply #120 on: April 28, 2014, 08:02:53 pm
are the "Marks" the cross on the top?
Bullet Whisperer
Reply #121 on: April 28, 2014, 09:06:02 pm
No, ignore the crosses. The dots on the cams and the timing pinion are what you need to look at. Ignore what appears to be a second, upper dot on this exhaust cam where it faces the inlet cam, it is just a stain. The lower dot is the one to look at. You can see that in this case, the inlet cam is retarded by 1 tooth in relation to it. The pair of dots together on the exhaust cam line up with the dot on the timing pinion.
 B.W.
« Last Edit: April 28, 2014, 09:13:55 pm by Bullet Whisperer »
armando_chavez
Reply #122 on: April 28, 2014, 11:36:53 pm
how can i clean these cams one of them has a slight rust color on one side?
azcatfan
  • 2002 Bullet ES
Reply #123 on: April 29, 2014, 12:16:04 am
Dry steel wool...
Bullet Whisperer
Reply #124 on: April 29, 2014, 07:36:18 am
Put them in the engine and run it, they will soon shine up  ;)
 B.W.
armando_chavez
Reply #125 on: May 25, 2014, 11:10:11 pm
So i put the S cams in today.  It feels like its so much harder to push the kick start lever down.  Idk why.  I would love some insight on how to perfectly adjust the pushrods.  its turns over and everything but it has yet to start. HELP
Reply #126 on: May 25, 2014, 11:54:12 pm
You need to stop where you are at and find someone to help you that knows and understands engine assembly.  I'm scared you're going to break your motor.    :-\
Scottie J
armando_chavez
Reply #127 on: May 26, 2014, 12:20:16 am
I just need some direction.  I put the cams in per direction. i kinda get the jist of how everything works.
armando_chavez
Reply #128 on: May 26, 2014, 12:29:52 am
I know for a fact i put the cams in correctly i just need to understand how to adjust the pushrods and how to
DanB
Reply #129 on: May 26, 2014, 03:44:44 am
To adjust pushrods... BW does include in his instructions to check for valve interference. So this before putting in plug. Don't bend a valve!
Go to You tube, search for "royal enfield adjust", find the video (link here: http://youtu.be/4bmgJPyCUNU) from hoohoohoblin. Ignore the part about the ammeter deflecting, find TDC, everything else is the same except for the wrench sizes. Do this with cold engine.
Good luck.
« Last Edit: May 26, 2014, 04:44:25 am by DanB »
2006 AVL Electra
armando_chavez
Reply #130 on: July 17, 2014, 10:57:54 pm
Did anyone have to adjust their carbs after installing S cams?  Also i feel like my kickstarter has gotten immensly harder to push down since installing s cams.  I got an old stock set, maybe its because theyre not broken in?
Reply #131 on: July 18, 2014, 06:37:11 pm
Without the compression release lever, you have to put moderate pressure on the kickstarter until the piston slowly gets past the compression at TDC, before you kick start it.
Allow the compression to leak past the rings, by giving foot pressure slowly, and it will be easier to kick after it gets to the top.
Home of the Fireball 535 !
armando_chavez
Reply #132 on: August 03, 2014, 11:25:17 pm
So i finally got my bike running put a hotter plug i found on the forums.  Is there any info on anybody trying 535cc with the S cams?
Reply #133 on: August 04, 2014, 12:48:12 am
What plug?
535 should work fine with the S cams.
armando_chavez
Reply #134 on: August 04, 2014, 01:03:30 am
i put the br6es equivalent that my local autoparts store had its a autolite 404 the thing would not start for the love of god with the 8
