Pipe Wrap
May 02, 2016, 08:11:50 pm
Author Topic: Yamaha Bolt Cafe  (Read 1755 times)
Guzzohm
Re: Yamaha Bolt Cafe
« Reply #15 on: November 16, 2013, 09:35:18 am »
Was that pebble to close to a vital organ to remove? Bike evolution being the way it is, dictates that if the belt was truly better all bikes would have it. How many are sporting the belt? Mostly cruisers? If you are the type of rider that may dissolve in oil it's a must have. ;D
The pebble was bulging out but not hitting anything.  Since it was in the middle of the wide belt, it was not a structural issue.  If it were near to the edge the belt likely would likely to have needing replacing.
Why don't all motorcycles have belts?  For sportbikes, maybe their power output causes undue strain on belts.  I would think the Enfields would be prime candidates for belts, except that they wouldn't fit the tradition, and would look out of place.  Witness the Buell Blast belt and rear "sprocket".
But didn't the first motorcycles have leather belts?  That's a tradition I wouldn't want to explore!   ;)
2007 Moto Guzzi Breva 750  "Karla"
« Reply #16 on: November 16, 2013, 10:06:34 am »
Sure I lose a little HP at the rear but so digging my shaft drive 1100 (Unless it breaks) ... :P
« Reply #17 on: November 16, 2013, 12:37:33 pm »
The shaft drive, at least, looks good!
« Reply #18 on: November 17, 2013, 08:42:13 am »
Early motorbikes did have leather belts.  But as torque increased, they were too stretchy and week.  Look at how large the leather belts on steam engines were!  The modern Kevlar reinforced belts with cog teeth don't have this problem.  They are strong enough to last as long or longer than steel chains.
« Reply #19 on: November 17, 2013, 11:28:04 am »
My belt barely hold my pants..Maybe I should try a chain and see how that works out.. ;D
« Reply #20 on: November 17, 2013, 04:12:11 pm »
My older brother has a Triumph primary chain belt he wore in the '60s.  It won't go around him now.  ;D
